Reset Sequential Function Chart (SFC)
Rony16
Nov 2018
Germany
hello
I am using a SFC function with rslogix and my question is:
if Step 4 or 10 is currently activ how can I reset (or abort) all SFC and go immediately to initial step? that can be needed for example by Automatic_Stop.
Can't you use a jump back to init step with transition looking at Automatic_Stop?
Be caustious if you have stored actions, you might need to add a intermediate step for resetting orders.
I can sure do that, but I will need to add jump for every step.
I was thinking about changing the contact_Bit to JSR from 1-0-1, this can (how i think) reset all Steps and stay at initial step.
but it should be there a better method?
Ah, I thought it was only step 4 and 10.
https://literature.rockwellautomation.com/idc/groups/literature/documents/pm/1756-pm006_-en-p.pdf
Page 49. I guess you have to do a SFR for each step to reset from? Maybe someone else knows?
thanks,
yes it seems to be the solution. as I understand it, I can use SFR to reset SFC and give "initial_step" to "StepName" of SFR.
but it seems too it needs SFP(execute) to restarts it.
logix designer-help says SFR will reset stored actions too.
Hi, i am using DVP-14SS2 PLC, after program written to plc, when power is reset, plc doesn't run. always need to connect to pc for the run mode.
36
Hi need help why this “failure 5 emergency stop “ appears at every startup in the morning ? Have to shut off main switch at least 10 times on...
19
338
I was loading a program onto an XE1e2 PLC and it got stuck on these two windows and won't progress. It won't let me connect from the PC to reload...
90
Hi all, i have recieved some 4RF Aprisa SR+ ethernet radios from a customer to configure. Issue is that they are used and have non-default...
97
Hi Guys, I have a 1769-L24-QBFCB1 that has the OK light flashing on the embedded counter module. The manual states it is a resettable fault, but...
114
