retentive db problem
seee
Dec 2010
singapor
112
hello.
i have cpu 315-2ag10-0ab0 and after power off and on the actual value of the data block become zero.
This cpu has mmc and as far as i know all of dbs should be retentive by default.
what is the problem?
best regards.
hello.
thanks a lot for your reply.
db properties is like the image which you have attached.
non retain has not been enabled.
in cpu properties,retentive tab i set mb0 to mb30 as retentive but after power on/off
the cpu, all memory bytes become zero.
i mean that in the cpu i don't have any retentive db,mb.
please help me.
best regards.
After power off and then power on the cpu all dbs actual values become zero.
cpu has mmc card and it should retain actual values but it doesn't retain.
(i set zero value on initial value of dbs).
there isn't ob100,ob101,ob102 in the program.
thank you very much for your help.
please excuse me because i took your precious time.
it was my programming mistake and i solved it.
best regards.
Hi all, Although I am working with my first Graphite display, this isn't my first go-around with Crimson. I started working with a few things on...
5,112
Hello everyone, I'm facing a problem with the retentive property of the allocated memory. I'm using bits (BOOL) of some %MW allocated registers...
2,739
Hello all, I'm an 'Instrumentation & Control System' final year student. Currently I'm doing my final year project and using PLC (OMRON) as my...
6,947
Hi all, I have what is likely not a complex issue, but I am working in Automation Studio and want an accumulating/retentive timer when a...
17
1,951
Having trouble with a Siemens S7 226 counter being retentive. I have specified in the System block C ranges offset 0, 6 elements. However, at...
289
