Retentive (latched) Operation in Omron CPM1A PLC
Hi
It becoming messy with all this pic but it easy.
1.Go setting (1) chose inputs 0.3 as interrupt .(PLC in Program)
2.In PLC Setting go to option Trasfer to PLC.The setting will trasfer to the PLC.
3.Copy (2&3) to file It should be the last file before the end (4).
(2) set the interupt.
(3)(This is the interrupt file each time input 0.3 go on the program jump and inc d201.)
4.Download it to your PLC.
Turn the PLC power Off Then On Then Run Mode.
It is very important to turn the power off and on in that way the setting would take effect.
PM me your e-mail I will send you all the project.
Good Luck
Hi all, I have what is likely not a complex issue, but I am working in Automation Studio and want an accumulating/retentive timer when a...
17
1,918
Having trouble with a Siemens S7 226 counter being retentive. I have specified in the System block C ranges offset 0, 6 elements. However, at...
281
Been a long time since I've posted, but here we go. Started a new role in august and progressively learning about Codesys programming in...
1,157
GE 90-30 using ME 6.0 - Newbie question... Let's say on rung 10 I set a coil (S) with a one-shot. Input to coil drops out, but coil stays...
30
11,097
Need some insight into why this happened. After finally getting a VM to connect to a CPU 216 2 siemens processor, uploaded the program. made a...
2,565
