Retentive relay , timer, counter, and data register number of mitsubishi fx2n 80mr pl
Dec 2013
Chittagong
19
Dear frnds.........
I m facing a problem in my project in mitsubishi plc fx2n 80mr. i want to back up my relay output . i mean i want them active after power failure. More clearly i can say that every output will regain their same position after power failure. Now, my problem is i can't retain my output in their old condition after power failure ........ Should i attach my program ?
PLs reply if anyone have idea about it........
thanks in advance
There are several ways you could put the machine as it was
But to have a power cut and then have the machine spring back to life is not one of them.
Thanks for ur reply.......................could u tell me few ways ? so that i can overcome my problem ....... when power will back i just want to put the machine as it was..... that's it..... should i use retentive relay or retentive data register........ if i use it then what's the addressing number for fx2n 80mr.......
i m attaching my program here........
Thanks in advance.....
after power back i will press start push button then the machine will regain it's old condition....... is that clear ? if it is not i will explain more clearly.......
here is the hardware manual for the FX2n
http://www.reyax.com/PLC/MITSUBISHI/FX2N.pdf
From there you can see which D registers you can use that are retentive and timers and and M relays.
Your program had no comments so it's virtually impossible to understand.
You are using a V index register for no other reason than incrementing a number (not what they are really used for)
Change the V0 for a D register (retentive start at D200) and increment that and change all your other D's to D200 and above
why not look at latching relays
Idec RY2KS Series
they will stay in the last position through a power failure
the do require 2 outputs set and reset
Thanks a lot ............. i have done my program last week.... It's been awesome..... Once again thank you guys........ Now i am looking to do this same program at s7 200 224 cpu ..... do you guys have any idea about retentive relay and data register of s7 200 224 cpu.
Thanks in advance
Hi all, I have what is likely not a complex issue, but I am working in Automation Studio and want an accumulating/retentive timer when a...
17
1,917
Having trouble with a Siemens S7 226 counter being retentive. I have specified in the System block C ranges offset 0, 6 elements. However, at...
278
Been a long time since I've posted, but here we go. Started a new role in august and progressively learning about Codesys programming in...
1,156
GE 90-30 using ME 6.0 - Newbie question... Let's say on rung 10 I set a coil (S) with a one-shot. Input to coil drops out, but coil stays...
30
11,094
Need some insight into why this happened. After finally getting a VM to connect to a CPU 216 2 siemens processor, uploaded the program. made a...
2,555
