but I have no clue so I guess its where to begin.
no guarantees - but the following might at least help get you STARTED ...
find an interesting OUTPUT device (for example a PUMP) that the system controls ... let's say that the address/tagname of the PUMP is Local:2:O.Data.4 ... if you don't know what each of the characters in that string means, then ask the forum for help ...
next use the RSLogix5000 software's Cross-Reference tool and track down all of the places in the code where that tagname exists ... to begin with, pay particular attention to entries where the "Destructive" column has a "Y" (for "Yes") ... those are the locations in the code where the tagname gets CONTROLLED (not actually "destroyed" in the usual sense of the word) ...
get a big sheet of paper and write small - use a pencil - not a pen ... make something like a roadmap which shows where the controlling signal COMES FROM - and - where it GOES TO ...
in the SIMPLEST cases you'll be tracing the logic/signals BACKWARDS (from right to left) through the ladder logic code ... for example: the OTE instruction for the PUMP - gets a signal through the FLOAT SWITCH - gets a signal through the CONTROL SWITCH ...
it might help to think about this stage of the game as something like untangling a large ball of string ... basically - find one end of the string (the OUTPUT device) and start picking the tangles out one-by-one ... this might not be easy - and it might not be quick - but it CAN be done ... that's because the logic is present/included IN the code ...
if you can follow the controlling signals for at least three or four steps back through the logic, then post a picture of what you've drawn out as an attachment to this thread ... we'll help you continue on from there ...
big question: are you allowed to post your program code (the .ACD file) here on the public forum? ... (make sure that your boss doesn't mind first) ... if you can do that, then that will help us give you more detailed help ... (note that you'll have to zip the file first - forum rule) ...
good luck with your project ...
