MASEngr
- Join Date
- Nov 2007
- Posts
- 79
I have a new PLC system that requires a fair bit of cooling. All the components dissipate 170W, worst case. (one hundred seventy watts) There's a DL-06, a few VFDs, and 4 5W safety controllers.
Here's where it gets tricky:
1. The cooling system has to be NEMA4 / IP66, since we're near the ocean.
2. There's no compressed air available, so vortex is out.
3. The cooling has to be small. The width can't be more than 6".
4. The outdoor temperature is up to 40C. (Heh, I can't use the word formed by amb + ient)
5. The components will start failing at 55C, so a limit of 50C is required.
6. The system is outdoors.
7. The system will be moving, so water cooling is out.
Some easy bits:
1. There's a large aluminum plate that can be used to remove a small amount of heat. (5' x 3')
2. There's a large plate on the front as well, although the users may be touching it, and it might get hot in the sun.
What in the world can I order that will let me cool this system off?
Thank you.
Some easy bits:
Thank you.
