Rice Lake 920i Scale HMI and data collection
rexcramer
Oct 2013
Michigan
34
I currently have a scale system and filling machine that uses a Rice Lake IQplus 355 HMI for weight indication and a MicroLogix 1200 PLC to run the machine itself.
Now MGT has decided they need data collection, so I am working on a data collection system using a ControlLogix PLC and Factory Talk Metrics for collection and reporting. All my research so far indicates that with an Ethernet/IP module installed the 920i SHOULD be able to collect batch and net weight data long enough for my ControlLogix to collect this data via Ethernet so I can generate reports via FT Metrics.
Before I go with the salesman's pitch and buy a couple of these I would like to know if anyone has any experience with this unit and Allen-Bradley systems compatability.
Have seen it working but I have not done it personally on a Rice Lake weight head. Have done something like this with a Metter Toledo weight head.
Bare in mind that the Ethernet adapter you plug into the Rice Lake weight head gets its data from a serial port so your data transfer will not be faster than serial speeds.
Thanks. I met with the Rice Lake rep today and things went well, it looks like this HMI should not have a problem sending data to the ControlLogix PLC after each tote is filled, which can then be collected by FT Metrics for report generation. I don't think data speeds are going to be a big factor since this is not a high speed machine.
I an curious about your experience with the Mettler Toledo head, as I have two different MT scales I am going to have to do the same thing with in the near future, both via Ethernet to ControlLogix processors.
One is going to be an XS unit and the other a new IND 560.
I did this exact thing with a 920. The 920 would write the weight value to a tag and I would read the tag and set it to a 0. This way I could continuously monitor the tag, and when the value wasn't a 0, I knew I had a new weight value. My 920 was part of a inline check weigher, weighing parts every 6 seconds with no speed issues, but this is relatively slow.
Hello fellow members, I have a project that has supplied the Rice Lake 920i with Ethernet TCP/IP® Interface 71986 (a Lantronix device)...
3,127
One of my customers is adding 3 920i Rice Lake scales to their Remote I/O network. They are using a PLC5 80/E. I have gone in and added the new...
4,914
I have a machine that is down. I have iRev and the info from the dealer to download to the indicator. But when I try to do so it tells me to put...
6,205
Has anyone used this scale transmitter with the Ethernet/IP option? I would be interested to see some sample code for how to zero and tare the...
1,886
I have shot myself in the foot - per se'.... I have a customer with a scale panel that has four Rice Lake scale heads in it. I was able to...
3,769
