RIO 1791-n4c2
saskcat
Feb 2011
sk
Hi everyone n Ken 2 :)
I have a rio network setup and running. The other day I installed an additional 1791-n4c2 on the network. As we were rushed to get this done, I forgot to tie in the comm wires. As the 504 was down to change the G file, I never noticed, and the guyz were chappin at the bit to get goin - I put the 504 into run.
So all was fine, but I then noticed no communication lines to the device. So I noticed the adjacent n4c2 and 8ar were working and communicating fine and so I connected comm wires and the comm lite lit up.
So my initial reaction iz that if a rio device failz - the the other devices continue to function. Yeh, I knew that. right? that iz true?
So I went to look at the i/o table and noticed that it has some values. But wait, the values are not functioning??? oh yeah - the device (n4c2) has to be configured (dumb a$$). ok, but this is two dayz later now. So I have the settingz figured out. I have a move instruction set to dump the value into the output table when the bit iz toggled.
The all important question iz -Will It accept the input and function, without shutting down the processor??? perhaps the n4c2 will need to be power cycled - still not a problem. I just don't need the hassle of having to restart the process - plus all the ****y guyz - you know how that iz :]
So whadda ya think? I'm 90% sure all will go fine. none of the inputz/outputz are referenced in the program, so there wont be conflictz that way. Both power and comm lites are green for GO!
anybody have any experience with this. itz more a rio question i guess. cheerz
I basically have a SLC 5/04 setup with 4 slots with the last slot having a 1747-SN ser.B. I have 3 other devices on the RIO link and they are...
2,724
Hi, I am a student at Conestoga College in Kitchener Ontario Canada, in Robotics and Automation. I am currently trying to connect three RIO cards...
2,034
It's my first time working with remote IO on a ControLogix system. I'm having some trouble getting an Allen Bradley 1791-16BC block IO module...
4,880
hello, I have a problem with my AN-X2-AB-DHRIO Prosoft module, I can't connect with the module because I lost a microSD card that has firmware and...
389
We have a remove PLC rack that is being used to collect data from older equipment via a 1756-DHRIO module. This module occasionally faults out...
419
