RIO Interface Cards
What software application are you going to use that runs the RIO protocol on a 1784-PKTX/PKTXD ?
The only software applications I've ever seen that implemented a RIO scanner on these cards were SoftLogix 5 and an old component called Sidewinder.
I'm not sure if RSLinx Enterprise can implement a RIO Adapter on these cards when run on an XP box.
It sounds like a neat application, and I'm curious what sort of software it is.
What i am trying to do ken is replace a pv 14ooe that is on RIO.
I want to use a versaview panel pc as we currently have the panelview 1400e and a versaview panel pc running a custom valve control application.
What i wanted to do is convert this pv 1400 code to rsview se station and run it on the versaview panel pc which has a spare pci slot for this 1784-PKTX card.
Will this work?
Hello. I'm new at this forum and I have some trouble to solve. I have here a HMI PV900 with RIO interface and I want to test this interface. This...
2,694
I have the following equipment. 3 - thermo ramsey 2301 intergraters each with AB RIO Board installed. 1.C3 scale, 230k, Rack 1.1 2.c23b scale...
3,687
hello, I have a problem with my AN-X2-AB-DHRIO Prosoft module, I can't connect with the module because I lost a microSD card that has firmware and...
401
We have a remove PLC rack that is being used to collect data from older equipment via a 1756-DHRIO module. This module occasionally faults out...
429
Does anyone have information or documentation regarding the protocol used in Rockwell's Remote IO, and how the physical layer of the network...
940
