Rockwell Codemeter
diat150
Mar 2006
Louisiana
1,475
Whats the true purpose of this? I just spent two days installing Rockwell software and noticed this software being installed and running. Quick search basically says we cant do anything about it. Just mostly interested in what exactly it is for. From what I have seen it is supposed to protect IP for both the end user and Rockwell. Is a webserver typically used to protect IP? Has anyone looked into what kind of info this software is collecting and broadcasting?
diat150 said:
Rockwell Codemeter
"CodeMeter" is not Rockwell's; it belongs to Wibu Systems. Other leading automation companies, such as Siemens, are also utilizing it...
ABOUT WIBU-SYSTEMS
diat150 said:
Whats the true purpose of this?...From what I have seen it is supposed to protect IP for both the end user and Rockwell. Is a webserver typically used to protect IP?...
For the sake of novices, EtherNet/IP junkies, sleepy-eyed folks, or simple dislikers of ambiguous acronyms - "IP", I assume, stands for "Intellectual Property" here?
Its "true" purpose is to provide License Based Source Protection...
704748 - Studio 5000 use of CodeMeter Runtime
Access Level: Everyone
diat150 said:
...Has anyone looked into what kind of info this software is collecting and broadcasting?
What has made you think it is doing that - perhaps the word "Meter"?
Regards,
George
Not really, there's plenty of examples where reputable companies send all sorts of info without requesting it back to their mothership. Assuming automation companies don't is simply too naïve and understanding what it actually does is nice to know.
I activated the Studio 5000 license with the CodeMeter on a virtual machine. Unfortunately with the subscription license I was unable to create...
1,280
Hello All This error popped up today out of the blue. I'm not quite sure the best way to proceed? I'd appreciate any help or direction anyone...
860
The way our rockwell licensing is set up (as far as I can tell) is that it is all hosted through CodeMeter. I have a VM with Licensing hosted...
1,262
I am working on a large migration of the standard PID instruction to the PlantPAx P_PIDE. Has anyone done a migration like this before and have a...
48
Hi all. What is the purpose of that block (MVM) when used with a 2#1111_1111_1111_1111 mask in that situation? I'm really hoping there is...
122
