Rockwell ControlLogix to ascii comms?
Softy
Oct 2010
England
Hello all,
A customer is replacing some equipment, and in this process a server utilising TCP/IP protocol will need to communicate with an existing 1956-L61 controller via ascii messaging.
I have used the Eweb module for this in the past, but it was a bit of a pain.
Has anyone used the Prosoft generic ascii/Ethernet interface module, or know of another ascii module that will do the task easily and efficiently?
TIA
I maybe misunderstanding some aspect of your setup here, but when you say ascii I'm thinking of serial communication. If so, then yes, there are a lot of serial ascii to ethernet module out there. I have used the Prosoft ascii (serial) to E/IP module and it's not too bad. Truth be told, they are all a bit of pain to setup but ProSoft got excellent phone support if you get stuck.
http://www.prosoft-technology.com/Products/Gateways/PLX3x/PLX31/EtherNet-IP-to-ASCII-4-Port
http://www.prosoft-technology.com/P...ic-ASCII-Serial-Enhanced-Communication-Module
Prosoft is my go-to solution because I know their configuration and operation method very well, but the easiest-to-use product for this sort of application is the Real Time Automation 490 series gateways.
http://www.rtaautomation.com/product/490tcpccontrol/
They make it very easy to set up a tag in the ControlLogix, do some configuration via a Web browser, and get data flowing fast.
Thanks for the replies - do these products allow for 2 way ascii communications? i.e. sending a string out as well as receiving one in?
The Prosoft is probably what I'll go for as it's readily available over here in the UK :)
Ran across this, could be trick or it could be real... not sure but they also have a Schneider example...
7,484
Hi All, Has anybody had any experience with this module - Softing OPC UA Server Controllogix module (setup, operation, etc.)? For this new...
2,805
We have an OPC Server for our Proprietary DCS which is currently communicating (bi-directionally) with a Wonderware front-end, but I'd like to use...
2,307
Need help. We have a plc that's cpu keeps getting maxed out. We've already upgraded it once. Now we need work on optimize it. We have over 50...
3,059
First of all, my thanks to the following members who tolerated my recent bellyaching about the scaling of input values in the thread "ControlLogix...
21
6,566
