Rockwell HMI TAG import / export wizare command line
eterc
Nov 2021
yhumaide
Hello everybody
I work for an organization that treats wastewater.
We are in the process of migrating 200 pumping stations to another communication system. I made a script allowing the conversion of the hmi tags to answer the new structure But what makes me lose time is the importation of the tags in supervision. The "tag import / export wizard" software is very slow and I would like to incorporate into my script the automatic import of new tags without going through the graphical interface of this software. Is there a way to use it from dos or powershell command line?
Thanks for your answers
Hi I have a couple of hmi panel view plus 700 Hmi and we keep dropping coms /stars in the data boxes I’ve checked the plc and unmanaged switch...
178
I want to program an Exor HMI using a Rockwell controller. However, when exporting the tag list from the controller and importing it into JMobile...
125
Hi All, I am taking a deep dive into my facilities HMI Thin Manager Server which has been alarming for High CPU usage. We are using FactoryTalk...
125
I have a PanelView hmi stuck at the boot screen. How can I make it run again? Allen-Bradley 2711-T10C15L1 PanelView 10.1" Touch Screen Terminal
2,483
Hi Experts! I am trying to get a Redlion Crimson 3.0 HMI to talk to a Rockwell Emulator. I imagine I'll have to use OPC DA. Has anyone done this...
1,180
