Rockwell Logix Plant PAx and Other HMI's
celichi
Apr 2008
Greater Toronto Area
415
Hello Ladies and Gentlemen.
I was wondering what the alternatives are to ME Station.
Can I use something like Ignition or Indusoft and still use AOI's and one tag?
Sorry if this is a stupid question, just wondering if I can get around paying $5k for a 10 inch (640x480) touch screen with CE PC with ~ 20 megs of usable memory for a mer.
Thanks,
Paul
Thanks for the reply.
Not worried about the work upfront to build a library for my needs.
The Rockwell PanelViews are expensive for what you get inside (processor, memory, screen res).
I find the Rockwell Pax code written with an "interesting" style, not easily understood at first glance.
I also find the Plant PAx objects are huge because they have to meet the world's needs, I don't need all the options, just a basic set for IO, and devices and a few Equipment Modules.
I would do away with the AOI in an AOI, and just build in the features I need (Interlocks, RT, Per missives, Mode and Alarms in one AOI with no nesting.
I am not a fan of using Alias Tagging either.
If you don't need all the things that the Pax AOIs do and don't like the cost associated with panelviews, and you are comfortable building your own library, I would build both the PLC and the HMI libraries. Maybe use the Pax objects as a base to get started?
I am comfortable building the Library.
Been doing process for 20 years, so I have a good idea of what the operator needs vs management.
Back to the original question, do other HMI software options, that can run on a PC, support the AOI, one tag, Direct tagging with the parent tag and all the children under it.
Global Objects with Global Parameter definition and tagging.
Does AdvancedHMI fit the bill? Those features may not be built-in, but they could certainly be coded easily enough.
Ignition does. When you browse the OPC, and drag a UDT/AOI tag to the tag library, all the children come with it. Caveat, you have to be online with the PLC to do so, as it doesn't have an offline browse of an ACD. However, you can also create your own UDT tag types on Ignition side, pass a single parameter to the type to identify the root tag, and then quickly create multiples of this tag in the tag DB. It's very powerful.
Absolutely. My favorite of the two you mentioned is Ignition. But, you should look at Indusoft, which is now Aveva Edge. I've never tried, but apparently Aveva can convert FactoryTrash ME/SE. This could save quite a bit of time. My issue with Aveva is software cost, they charge for development and in my experience the runtime licenses are more than Ignition.
Hi... I have what is so-called "Limit Values" placed in the Safety PLC. These values ​​were written in REAL safety tags format. It turns out...
429
Hi All, I have a requirement of communicating my 5380 CPU with Zebra ZT411 Printer. Is there any one who did this before ? Do we need to have...
928
Good Evening, I'm loading a recipe into a Rockwell ControlLogix or CompactLogix CPU via Excel, this is all working fine. Is there anyway I can...
2,048
Hi All Predictably, I have a problem making Intouch talk to compactlogix 5380 plc !!! In Intouch I've declared : Access name = Tank_Farm Node...
703
Hi AllN Predictably, I have a problem making Intouch talk to compactlogix 5380 plc !!! In Intouch I've declared : Access name = Tank_Farm Node...
3,143
