Rockwell Modbus TCP AOI help
BeepBob
Jan 2023
Oakland, CA
107
Hello,
I am trying the AOI provided by Rockwell to read Modbus TCP, the version is 2.04
The connection looks good to the modbus server.
I am trying to read holding register 1000, function code 3, count 3
I use modbus poll (another software) and I read it fine. I just do not see the data while monitoring in studio 5000.
The transaction code says a "1" so its a success.
The data is under the .LocalAddress parameter right? Why is the default "0" for the .LocalAddress, do I need to change it? The manual wasn't clear
Can someone spot if I set this up right?
Attached screen shot.
Your data will be under Gate_01_Data.HoldRegisters_4xxx[0] - Gate_01_Data.HoldRegisters_4xxx[2].
If you change .LocalAddress (for example) to 5, then data will be under Gate_01_Data.HoldRegisters_4xxx[5] - Gate_01_Data.HoldRegisters_4xxx[7]
Yeah! that was it, the manual didn't specify. Thank you!
Question when I explanded Gate_01.Data, it shows hundreds of register. Is there an option for the AOI not to create so many tags?
Another bonus question..The manual says MAXIMUM 5 transaction per AOI.
Is this a software limit? Has anyone modified this AOI to have more transaction?
Can I just modify the raC_UDT_ModbusClientTransaction[5] array to be one bigger?
As far as I know, the 5 transaction limit is based on performance as they execute sequentially. You can change array size and the AOI will pick this change automatically.
As for the data size, you can change the number of registers and code will check that. However, if change Boolean arrays 0 and 1, then you will have to manually specify limits. But booleans take relatively small memory and you can leave that as-is.
I have a PH meter that I am trying to bring its data into 1756-L81. I have downloaded the Rockwell MODBUS AOI kit, but I am not sure if I need to...
164
Hi. My Lumen guy isn't answering me and we're almost ready to complete the conceptual part of the design and we'd like to order soon. The...
684
Good Afternoon , I have a project coming up for a labeler and a CompactLogix PLC . The communication for this labeler is Modbus / TCP ...
2,377
Hi all. This is a very specific issue. My first time with a Modbus ProSoft. Customer setup doesn't make any sense but we're stuck with it...
372
I am trying to connect to a Chiller through Modbus TCP that has been setup as a Modbus slave and I see the Rockwell AOI and it looks pretty...
378
