rockwell rslogix 500 lead lag lag1 pump questions
8803809
Jun 2009
ok
Hi All
Can anyway shed some light on Lead/Lag/lag1 for Pump operation based on level setpoint? Where can i find a simple project about this? Any help will be appreciated. Thanks in advance
Regards
Here are some info:
The EEB pumps start and stop automatically based on the following sequence:
Start/Stop Sequence:The EEB Pump will operate on a lead/lag/lag1 staging sequence. When EEB level reaches the start lead/lag/lag1 start levels the corresponding pump starts. As the level drops the pumps stop in lag1/lag/lead sequence.
When all three pumps are stopped the lead/lag sequencer will rotate the lead, lag and standby pumps in one of the following sequences: 1-2-3, 2-3-1, 3-1-2.
I am quite new to Rockwell 500.
The logic involved is not specific to RSLogix 500.
What do you have so far?
If nothing, have you taken a look at the simulator available on this website? Prove out your logic on the simulator, then adapt it to RSLogix 500.
I just want to see if there any example related to this lead/lag/lag1 pump operation based on level setpoints for Rslogix 500?
I've done this with 2 pumps on a PICO.
One way would be to use a counter. Each time the level switch closed it would advance the counter. Count of 1 would be subroutine 1 with whatever order of run/stop. Count 2 the next routine, etc.
Rockwell Allen Bradley Programming Software, RSLogix 5, RSLogix 500, RS Linx, RSLogix 5000, version 2007, 1 DVD ----------------------- The old...
21
86,739
L
I just saw this on www.controls.net. A-B Rockwell is going to give away fully licensed copies RSLogix 500 Pro during the month of April. They...
33,652
Hey, Can you guys help explain this to me, I have always seem to get this confused. The question is whats the difference between the Rslogix 5000...
5,240
Just a word of warning for those of you that are thinking about installing version 3.0. In the very end of the EULA, there are some significant...
5,469
Hi guys. I have left Rockwell support a message and waiting for a call back, hopefully this evening.. but want to ask fellow PLC'ers for advice...
34,529
