Rockwell System Architecture
Mihir_007
Apr 2014
Reading
66
Hello folks,
We have a huge rockwell's critical control network installed in plant. For which for individual system, i want to generate a network architecture.
Is there any software available from rockwell or any other vendors that can identify the instal software and can let us know in which manner the system architecture is installed. i.e., from where ethernet cable is going to which device.
Thanks.🤞🏻
someone else had the same question here http://www.plctalk.net/qanda/showthread.php?p=687494
1. If you are using managed switches each switch will tell you what MAC address is on each port. Then go to each device and record it's MAC address usually printed on the device, or associate IP addresses with MAC addresses for ARP table.
2. unplug a cable and see which port on which switch has the link light turn off
3. one person recommended http://www.solarwinds.com/network-topology-mapper.aspx but maybe it only works on managed switches
It is surprising that such a critical network would not have documentation.
Maybe the network integrator has it and you can contact them?
If not then the network cabling should at least be labeled. If you made a hand sketched map of all the devices and cables you would at least have a start.
I think a lot of the network mapping software would have difficulty giving you a good representation through routers and firewalls, only the local subnet.
Does Rslinx, rs500, rs5000, studio5000, have drivers for Windows 11 pro. I'm in need of a new laptop for programming with all of this software. I...
4,255
Hello, In a Ring Network , we can configure device as Active Ring Supervisor and Backup Ring supervisors. In a single Ring network we can have...
2,223
This is a bit of a rant lol, my first 5 years as a systems integrator was using Siemens, then I came to the dark side of Allen Bradley / Rockwell...
67
23,839
Good morning, I am designing a robot similar to "Schubert F2". I have already solved the inverse kinematic, trajectory, speed and stuff, but...
2,234
Hi, I plan to change the PLC from Omron to Rockwell and according to PLCOpen that they add independent schemes to IEC 61131-3 in XML format, So...
2,503
