Coordinated System Rockwell // Allen BRadley
jose_jmap
May 2019
Cordoba
Good morning,
I am designing a robot similar to "Schubert F2". I have already solved the inverse kinematic, trajectory, speed and stuff, but to design the controller, I have been recommended the use of the Rockwell // Allen Bradley PLC, because it has integrated the coordinate system (the "Schubert F2" robot is similar to the "Articulated Dependent Coordinate System").
My doubt is: I am setting RSLogix, configuring the PLC, SERCO and Kinetix, as well a the two controlled axes. I have also created the articulated dependent coordinate system, with its geometry and axis associated. However, I can't find anything about how to set the trajectory profile of the end effector or, failing that, the profile of the servo angles.
I would like to know if someone has worked with something similar or knows where to find a tutorial or example solved. Thanks
Greetings.
please keep us posted on your progress. I have worked on with the f2 and would be interested to see your end result.
Hi, now I'm working with a sample project included on RSLogix 5000 which programs an articulated independent robot using coordinate system.
It sets two coordinate systems: a Cartesian and a Articulated independent. Then it uses instructions MCT for the kinematics transformation and instructions MCLM and MCCM to indicate the movement (linear and circulate) of the end effector
I have two 2198-P070 bus power supplies for that I’m using for four Kinetix drives, 2 drives per power supply, all controlled by one processor...
1,428
Hello Everyone 🍻 Im working with Coordinated Motion instructions, specifically MCLM instruction and I Would like to know if there is a...
753
I have a unique project and will be commissioning it next week. It involves two servos that are both connected to the same belt in an H-type...
22
14,126
Hello everyone, I need to control a discharge pressure in our pipeline and there's two ways of doing this: 1. By controlling the speed of the...
2,152
Hi, I have a project to automate a molding machine. It meters out a 2-part resin into open face molding plates, closes the plates, vacuums them...
3,238
