Kinetix 5700 Motion Coordinated system
dingomex3
Mar 2012
mexico
33
I have two 2198-P070 bus power supplies for that I’m using for four Kinetix drives, 2 drives per power supply, all controlled by one processor (5069-L350ERMS2). I have an enable contactor setup for each power supply for each set of drives. I have them configured as DC bus groups 1 and 2 respectively. I had the first set of drives working, setup inside the motion group, with no issues. When I added the second power supply and drives. I found that when I added them to the motion group I couldn’t get the enable contactor to close for the first set of drives. I f I took them out of the motion group and made them ungrouped then the first contactor would close but then I couldn’t get the contactor on the second set to close. Do you have any thoughts as to what I might be missing to get these to work? See the screen shots for more detail. Let me know what you think.
Everyone, I am having an issue with our current program and need advice. Our current setup has 4 servos running on a pusher chain conveyor. The...
478
Kindly, we have the following faults with a Kinetix 5700 servodrive. We checked the encoder cable, but found nothing damaged. What could be...
286
Hello everyone: I am looking at the possibility of migrating Kinetix 6000 to Kinetix 5700(460V 3 phase). Reviewing the drive catalog, I have the...
1,141
First time poster and somewhat new to PLC programming. I own a brewery, have a programming background, and one of the machines on my canning line...
973
Hi When using Studio 5000 & Kinetix 5700 drives would it be possible to change drive setup from the PLC code. the senario is that i have a servo...
481
