Kinetix 5700 Startup STO Faults
thunberg
Sep 2023
Rhode Island
First time poster and somewhat new to PLC programming. I own a brewery, have a programming background, and one of the machines on my canning line is a serial #1 prototype that I'm working some bugs out of.
I purchased Studio 5000, have made progress on fixing a few bugs, but one I'd appreciate help with relates to initial / startup safe torque-off faults on Kinetix 5700 drives (Inhibit S05).
STO is being handled in the program (not hardwired) and my question is: how are initial / startup faults usually dealt with? Are they force cleared in the program? Is the operator supposed to press a fault clear button?
Alternatively, is there a cleaner way to do this so that Inhibit S05 faults don't occur at startup?
Thank you in advance for the help
I don't know if this applies to the 5700, but with the PowerFlex VFDs, I set them to not fault when STO opens (they have a parameter for this behavior). You'll have to do a risk assessment to be sure, but in general, you do want the operator to take positive action to reset the safety circuit. I just prefer the drive not also fault. Since you're handling STO in the program, I assume you have a GuardLogix PLC?
I'm almost finished setting up a new system and have a few lingering issues. The system: 2198-P031 power supply 2 x 2198-D012-ERS3 axis modules...
8,884
Kindly, we have the following faults with a Kinetix 5700 servodrive. We checked the encoder cable, but found nothing damaged. What could be...
285
Hello everyone: I am looking at the possibility of migrating Kinetix 6000 to Kinetix 5700(460V 3 phase). Reviewing the drive catalog, I have the...
1,139
Everyone, I am having an issue with our current program and need advice. Our current setup has 4 servos running on a pusher chain conveyor. The...
477
Hi When using Studio 5000 & Kinetix 5700 drives would it be possible to change drive setup from the PLC code. the senario is that i have a servo...
479
