Rockwell VantagePoint to Beckoff PLC
Corkman
May 2014
Cork
Hi all,
I'm wondering if anyone here has successfully collected data in Rockwells VantagePoint from a Beckoff PLC (TwinCAT). (I am collecting from ControlLogix and CompactLogix at present)
What licenses are required to do it? VantagePoint OPC Connector + Kepware OPC or VantagePoint OPC Connector + Beckoff OPC
or any other method?
Thanks,
Corkman
The easiest way would be to turn on the Beckoff OPC server (OPC UA is faster/easier, but they should have an OPC DA option to be backwards compatible with Rockwell). You most likely don't have to license the Beckoff OPC server and I don't think Kepware supports Beckoff anyway.
The Beckoff OPC is an option so not sure what that means in term of licensing, plus I just found Kepware has Beckoff listed but I'm also not sure if this is any good.
You will need an OPC license for VantagePoint. Whether you use Kepware or their own OPC server, you still have to have a VP license for the OPC connection.
OG
Ok thanks for that Operaghost, I'd better get onto our local distributer in that case. I wonder what the cost of this will be??
I was looking at Rockwell's description of what comes with VantagePoint and noticed it included MS SQL Server with a Runtime Restricted License...
2,423
Hi All, Wondering if anyone has a source for information about products with problematic production runs from allen bradley/rockwell. Ive seen...
26
I have a PH meter that I am trying to bring its data into 1756-L81. I have downloaded the Rockwell MODBUS AOI kit, but I am not sure if I need to...
176
Hi all. Customer wants analog faceplates really bad, even if we explained that it doesn't make much sense in his process. What he wants to see...
130
Hello, recently I saw a graphic from any Rockwell App, I cant identify which one is. Attached a SS. Its used to see dashboard from datapoints and...
131
