Rockwell
RSView 32 7.20 When I open the app. I receive error "failed to launch vba server". I can open other application with no problem. Running on XP Pro.
Straight from the Rockwell Knowledgebase
Cause:
The VBA Project has a reference to an Object Library that is not installed on the computer. This is most likely to occur when sharing projects between computers.
Solution:
Open the RSView32 project on the computer that originated the project and record all referenced Object Libraries in the VBA IDE. Make sure these Object Libraries are all properly installed on the destination computer.
OG
Runtime Error!
Program:C:\Programs Files\Rockwell Software\Rsview\SPTED32.exe
This application has requested the runtime to terminate it in an unusual way.
You really need to post better questions..............
Is this a NEW message? Is this occuring AFTER the VBA message?
PLEASE help us help you.
OG
OK..........
Did you read the post above from the Rockwell Knowledgebase? It sounds like the projects you are trying to open were copied from another computer, but not all files got copied. That would explain why a new app does not get these errors.
Go to the machine(s) where the originals are located. Use the Transport Utility to copy all files and folders.
OG
This is computer developed on. But your right I removed the the .vba file it opened with no problem. I will try and replave the .vba file. In my dreams!!!!
I have got an Rockwell PLC 1769-L36ERMS . I have assigned a IP address to it . But every-time I Reboot the PLC it looses Communication to my PC...
67
Hi all. I have 1793-IE4 (4)analog inputs modules in a 1794-ADN IOFlex DeviceNet Rack. I cannot find if I can I have access to individual channel...
33
Hi All, Wondering if anyone has a source for information about products with problematic production runs from allen bradley/rockwell. Ive seen...
126
I have a PH meter that I am trying to bring its data into 1756-L81. I have downloaded the Rockwell MODBUS AOI kit, but I am not sure if I need to...
192
Hi all. Customer wants analog faceplates really bad, even if we explained that it doesn't make much sense in his process. What he wants to see...
134
