rotate text in RSView
d x l
Mar 2005
Midwest
30
Simple question: is it possible to rotate text in RSView?
When I import a .dxf I can see rotated text, but the text is too long and RSView won't let me resize the box. If I try to change the font size, it goes horizontal and then I can't rotate it back.
I use RSView32 and if memory serves me correctly, you can’t rotate the text. I think I was told to use paint and copy and paste.
I just tried and could not rotate the text. You could use paint and rotate it in there at least you could get 0, 90 180 or 270 and then copy and paste.
Hi all, I have a powerflex 525 which I'll be using in VVC mode, and the manual says I should perform a rotate tune to use the drive in VVC mode...
3,533
Dear Expert. I have problem to rotating the objects. (object from Graphics) Tool bar, Format menu, Rotate is disable. Is there any option to...
2,125
Im Looking for a way in codesys visualization to rotate an image based on a variable. I know the polygon is the only object that allows rotation...
5,018
hi, i have rotated an object in clockwise direction up to an angle based on requirement...my doubt is,,is it possible to rotate an object in...
2,722
