RPM Display using AB Micro820
jmaty23
Mar 2009
New York
49
I am looking to detect the RPM/speed of a conveyor belt using a Micro820 processor and a magnetic sensor.
The magnetic sensor would pickup the teeth of a timing sprocket which would be connected to a digital input on the 820 processor.
My question is, how would I program the Micro820 to read the DI and display the RPM/speed on the HMI??
I have been messing around with Connect Components Workbench to try and figure it out for the past 2 days with no success. This is my first project with CCW.
I am using this hardware because we already had it available to use.
Any ideas?
Thanks, I did search RPM in the forum but could not seem to find anything to assist me. This will get me going. From the post that you linked to, it lists the use of a one-shot relay in the ladder logic. I am used to using this in RSLOGIX but do you know if this function is available in Connected Components Workbench? I can't seem to find it anywhere.
I am in the same boat as BCS. (no pun intended) never used CCW. But in the old processors you had to make your own ONE SHOT. You could do this by first Resetting the bit. Then the next rung use logic to set bit.
------------------------------(U)
---||-------------------------(L)
This would allow Latch to be true for only one scan.
So any Logic you need to be solved from Latch would be placed below the Latch and the following Rungs.
Hello I am new to programming Analog inputs and am wondering how to use the analog output from my inverter drive to an analog input on the...
7,314
Hello all experts, I am doing a project in which I have to display voltage,current and RPM of a battery operated vehicle. I need to input these...
2,949
Hello, I have some drives which are controlled by pressure transmitters, PID controllers etc.. I'm a bit confused about the frequency of the...
3,417
Hello, I have a motor that we are sending a RPM Speed Output from 0-100% to the VFD. However, the Motor HP needs to be limited to 6000 HP and the...
91
Hi everyone, This is my first time posting, so please forgive any omissions or mistakes. I am attempting to control the velocity of a stepper...
18
1,019
