RS-422 For Controllogix
CarlosMP
Dec 2006
canarias
I’m reconverting an old instrument to a PLC system using a controllogix technologic, but I got 2 old Ferranti encoder with a RS-422 protocol, Somebody know any module I can used for reading this RS-422?
Is it actually RS-422 communications? or rather just the specification for full differential line driver outputs?
If it's a regular A/Abar B/Bbar output encoder, it can connect directly to a 1756-HSC module.
The encoder is a 35HA optical absolute encoder with 20 bits, the encoder receiver and transmitter conform to RS-422 with serial data in a standard UART format. For me will be nice if a can convert the RS-422 to SSI format, if I can not find a controllogix module RS-422 then probably I have to use a pic controller to convert in SSI format.
Given the fact that people use this as a rs-232 extender, I imagine you could find appropriate converters.
MELSEC A RS422 (25pin) <> iQR C24 Serial RS232 (9pin) - Simple PLC Communication Communication from a MELSEC-A Series CPU (RS-422 – DB 25 Pin)...
1,054
I have an application I'm considering where I need a device that's generating a master encoder output signal to drive two slave devices at the...
2,555
Hello All, I have been trolling through the Proface documentation to find an answer, but I read conflicting information. We have a...
3,950
This is a little OT but I'm looking for anyone with experience with the Yaskawa Sigma 5 servo drives. We've had some servo drive and motor...
3,552
Hi, Im a bit unsure about how to connect my SIEMENS encoder (5V TTL/RS422) To my baseunit (The light one).. I have attached a pic of how i have...
1,542
