RS 422 Wiring to DB 9
Tim Ganz
Dec 2010
Dallas, Texas
700
I have a RS 232 to 422 converter box and I have cables from the computers 232 serial port to the converter box but i need to make a 422 cable with db 9 ends. Can anyone point me to a good pinout?
All that i have found shows only 1 end of the cable. Does this mean that 422 cables are straight through with the same pinout on each end.
RS 232 flips a couple wires correct?
While RS232 has pin definitions RS422/RS485 does not. Everyone makes up their own. The wiring will be totally dependent on the devices involved. Many times you will see RS232 to RS422/485 convertors with wiring terminals on the RS422/485 side because there is no definition.
Hi, Im a bit unsure about how to connect my SIEMENS encoder (5V TTL/RS422) To my baseunit (The light one).. I have attached a pic of how i have...
1,543
MELSEC A RS422 (25pin) <> iQR C24 Serial RS232 (9pin) - Simple PLC Communication Communication from a MELSEC-A Series CPU (RS-422 – DB 25 Pin)...
1,055
I have an application I'm considering where I need a device that's generating a master encoder output signal to drive two slave devices at the...
2,555
Hello All, I have been trolling through the Proface documentation to find an answer, but I read conflicting information. We have a...
3,953
This is a little OT but I'm looking for anyone with experience with the Yaskawa Sigma 5 servo drives. We've had some servo drive and motor...
3,553
