RS 485 and the bus system
wolf691
Dec 2005
Johor
Hi everybody,
anyone can explain to me the relation of rs485 and the bus system like modbus, profibus and devicenet ?
thanks & regards !
RS485 is a transmission standard (2 wire). RS485 is 4 wire. Modbus is a protocol. There are several flavours of Modbus. The most popular is still Modbus RTU.
Have a look at www.modbus.com for information about the various Modbus protocols.
So can i say profibus and devicenet also transmit through the rs485 ??
Not really. I do not know much about Profibus but use Device Net regularly.
Here is a link to a site where most/all industrial networks are listed and described. There are also some good links here about the respective networks.
http://ourworld.cs.com/rahulsebos/
Here is a link to the Device Net website
http://www.odva.org/
Yes, Profibus uses the RS-485 transmission standard.
Since Modbus is a protocol, it can run on RS-232 or RS-485 or even a current loop. When it runs over ethernet, it is called Modbus TCP.
Dan
A quick analogy would be like this: RS-232,485 or whatever is the type of highway/road. Modbus is just a type of vheical used to transmit information on that road.
I'm trying to control a device via MODBUS RTU and the ModbusRtuMasterV2_PcCOM in Twincat 3. I've configured a device with the right com port and...
272
Does anyone know of an AOI using the user ASCII protocol select on the L6x controllers that will talk Modbus RTU using RS-485? Thanks, Trevor...
171
Hello, I need to access the bits from the fire system control panel through RS-485. So, I used Read Var block to read from the panel...
214
I am trying to figure out some communication specifics for a Modbus RTU network that I will be integrating with and could use some help to make...
2,139
Good day all. I have an RS-485 topology question. I am hoping for some guidance so that I can make a confident calculation/decision that this will...
1,538
