Rs 485
kumar satyam
Oct 2011
hyderabad
30
I have a Rs 485 On my PLC (B & R). I have to communicate it to a HMI having a serial port through a Converter . It was running since last 5 years .But nOw commu nication is Fail. HOw can I check RS 485 port and Converter.
I'm trying to control a device via MODBUS RTU and the ModbusRtuMasterV2_PcCOM in Twincat 3. I've configured a device with the right com port and...
225
I'm trying to write a data in Arduino using MODWR function block .I used the code I got from online for both PLC and Arduino. I made the wiring...
121
Does anyone know of an AOI using the user ASCII protocol select on the L6x controllers that will talk Modbus RTU using RS-485? Thanks, Trevor...
142
Hello, I'm trying to delve a little into rs-485 communications for a couple projects of mine. Until now I've been using a delta vfd and a delta...
125
Hello, I need to access the bits from the fire system control panel through RS-485. So, I used Read Var block to read from the panel...
200
