rs 500 and 5/04 will not SCP
tlhigham
Dec 2012
tn
Hello,I am relatively new to PLC programming and new to this forum. I am having an issue with a trainer that I have just built. It is a 5/04 processor with I/O and a 1746-NI4, 1746-NO4V and a 1746-NT4.
I am using rs 500 ver.6.2.
Iam being told when I try to write a program with the SCP instruction that the instruction is not supported in the current processor.
Can anyone tell me what may be the problem? Thanks in advance,Terry Higham
Sorry if this shows up twice, but I had posted on practice posting and wasn't sure if it would post in Q&A.
1747-L542 Ser.A O.S.#1747-OS400 Ser A FRN 4
OS400 didn't support SCP, but OS401 does. You can Upgrade your PLC Firmware fairly cheaply to the latest revision. It might be worth contacting your local AB Supplier.
Stu....
Rs logix 500 is version 12.00.00 and my SCP instruction is grayed outed. Can anyone help?
1,311
When using 4 to 20mA I have been using 3277 to 16384 for the input min and max. We had new controls put in for a machine several years ago and...
1,658
Hello all, I'm having an issue displaying the value I'm getting from a PFC to display on my Red Lion G307..... and before anyone says it...I...
2,142
When I try to enter a new value into the SCP to see if a 4-20ma operated valve will stroke, the value for the input setting goes back to the...
2,460
hi guys, i need help i have a automation direct hmi and vfd and i have a ab ML1200 i have wrote a program to run the vfd and to use a the hmi to...
18
15,982
