-=| RS Logix 500 & Wonderware |=-
JuNGLisT
Sep 2003
North Carolina
31
Is it possibly to have RS Logix 500 and Wonderware running on the same computer at the same time? Or is the node address a conflict and you can only run one or the other.
Why not just try it and see! It's not like you're going to break anything... Either it'll work or it won't. And if it doesn't, figure out why not.
But - the answer you want is that it's not a problem. I've done it many, many times.
Running them on the same computer is fine but going online with RSLogix500 while WW is running depends on the driver and communication type. Ethernet, should be ok with WW IO server and AB RSLinx running simultaneously. DH+, I think you will need RSLinx for both since only one driver can access the DH+ card at a time. Serial, only one driver at a time and only one appication at a time online.
I am using Wonderware Indusoft with RSlogix Emulate 500 on my laptop. When I run Indusfot, my data are not population on HMI screen, and I get...
972
Sorry for these basic questions. I'm a traditional structured text programmer who's been asked to take over the PLC and HMI coding here and I'm...
2,876
im trying to get a wonderware application to talk to a micrologix 1500 thru a digi one iap. I can see and go online with the micrologix 1500 thru...
6,080
Hi Everyone, I am not proficient in RSLogix 500 so I have a question regarding the evaluation of N7:0 data as an input. So as I understand in...
87
89
