RS Logix 5K, trying to add module, not in list, HELP
fluid
Feb 2009
BC
As the title says. In RS Lgx 5K, I want to add a new module. When the list comes up, my desired module is not shown....How can I "import" this module into RSLGX5K ??
Which is the catalog # of that module?
Sometimes you need to install an Add-on profile from this LINK.
Or maybe you may configure it as a generic module...
- [FONT=comic sans ms,sans-serif]fuzzy logic[/FONT]
Thank-you, that was the answer.....
If you posted the version of RSLogix 5000 you have, and the part number of the module you wanted to use, the answer might be of some use to other and future Forum members.
How about it ?
Hi all, I'm starting work on a system and the processor for said project is a Control Logix 1756-L82. When I open Logix, however, that CPU is...
2,946
Does anyone have experience communicating with the MAGPOWR Cygus Tension Controller thru Ethernet. I have a Controllogix 1756-L73 PLC Version 30...
25
4,079
Hey everyone, I have a Keyence LK-G5001P control module with 2 laser heads connected to it (the lasers are Keyence LK-H152). I have the control...
2,184
Good Morning , I received a used 1756-L62 / A CPU , from a vendor that was using it for a trainer. I tried to download a program that is...
1,477
Regards, I have never had any problems communicating through rslinx with the AB plcs, but I have run into a serious problem, which is that I have...
1,145
