RS Logix TRENDS config?
gnothstein
May 2004
Georgia
Hi everyone,
Could someone tell me how to configure a trends chart in RS Logix to reflect different values for scanned bits that each would normally have a 0 for OFF and a 1 for ON so that they can be tracked at the same time without overlaying each other or one hiding another on the chart? Your help would certainly be appreciated.
Hope y'all are having a great day! THANKS. :cool:
Somewhere there is a check mark that you can place to seperate all the trends, All trends will have there own "space" in the display.
The other option is to have different min/max values so they are at different spots, but that is not as easy.
Drewcrew6
Right click on the chart once it is opened and choose Chart Properties. Then on the Y-Axis select Isolated Graphing. Then enter a % isolation (I usually use 5%) as a buffer space between the pens.
Hope that helps!!
OG
Re: RS Logix TRENDS
:D THANK YOU....that was great info,,,,I had not done a trends in some time and now maybe I'll remember. It's terrible when your mind starts to go!!!
Morning all, my question for the day is can I build and save multiple trends in control logic? working on a boiler, I have several different...
1,087
Hello guys Im troubleshooting some equipments but im using some trends to get the problem signal. The rslogix 5000 only let me display signals...
2,143
Hello I put my computer to log all day some equipments, and I want to review certain times, but when I open the log file I cant go to the desired...
2,207
Hi, I am trying to gain some data by utilising the trend feature in RSLOGIX 5. I have a trend set up and I walk away. Its logging the data but...
4,970
B
Hello all. Im getting a call every coupla weeks that a mill is just "shutting down." I have Very serious suspicions that a normal stop is being...
4,219
