RS view - hmi tag alarm summary
Song99
Mar 2010
San diego
From help file:
"An HMI tag alarm summary is a FactoryTalk View graphic object that you create and place on a display in the Graphics editor. As alarms occur, they are stored in the HMI tag alarm summary data store on the computer hosting the HMI server that is monitoring HMI tag alarms. "
"Use the Execute option on the Data menu to specify a FactoryTalk View command or macro to be run when the Execute button is clicked or an item in the alarm summary is double-clicked, at run time.
Use the check boxes beside the items in the Parameter portion of the Execute command dialog box, to specify the parameters that will be used with the command. These parameters will provide information about the alarm transaction that is highlighted in the HMI tag alarm summary when the command is run."
Seems like the system has a way to know what alarm transaction is highlited and it passes the associated paramters (tag name, severity, value etc) if a command is executed. what I am trying to achieve is to obtain those paremeters and use them somewhere in the same display. such as i want to get the tag name of that highlighted alarm. is there any way to do it ? including vb script?
your expertise opinion is greatly appreciated.
Hi. When exporting an hmi tag data base to .csv, there are two steps that excel comes up with in choosing the correct format, does anybody know...
872
I would like to cause an HMI tag to change value (digital) when a certain PLC tag changes value. Is there a way to do this? Specifically I would...
1,939
We are cutting over a PLC5 to ControlLogix and we ran into some issues with the HMI (FTView v10, Network Distributed). We found that after...
958
Good Afternoon , I'm doing a FactoryTalk View application ME, and I have a Momentary Pushbutton that I have the correct tag attached to it...
2,136
It's been a bit since I've used tag alarms in SE, and I'm having trouble showing them. I have a digital tag, with the alarm checkbox CHECKED, and...
2,334
