kurt.brinker
OP
i am only monitoring data with rsview SE. I created a datalog and then setup a trend. The section where you add pens has a button to "add pens from model". click that, select your data log and add whatever tags you need. also make sure your trend is set to "real time data server" then start the datalog via the command prompt
i just saved everything after that and it worked great.
