RS View Studio ME- Tags and Multistate PB
Coachman
Sep 2006
Maryland
97
I may be missing something here and most likely ,I am. I would like to put a multistate on my display ,but I would like to put a Auto,Off and Hand, but I see that you can only have 1 tag attached
to this Pushbutton ,of course you have a tag for the indicator
coming back. As you know ,space is always limited. Would you have
any ideas.
Thanks In Advance,
I don't have the software in front of me at the moment, but doesn't it give you an option to write an expression? On the connection tab, you should be able to select Tag or Expression.
You should be able to build an expression to do what you need.
OG
Hello;
When you use a multistate display, only one tag is needed, an integer tag. Use the PLC logic to change the value of this tag as needed (such as Auto = 1, Hand =2, Off = 3), and assign different states (gfx images) to the multistate display.
Hope this helps,
Daniel Chartier
Fast on the trigger, n_lev!
Hello all. Is there a way to upload alarm tags at the bit level to my FTView studio? I export them from my PLC thinking I will upload them to...
425
Hello all. I am trying to establish my connections in FTView Studio. Normally, after I have set up my offline tag file in communication setup I...
663
So I have copied the MER file from a panelview and converted to MED file. How to get updated tags to use in displays. I know i have to do...
1,892
I'm having an issue with getting animation to work as I expect it should work. It only seems to change when I exit the display, then come back to...
5,256
I am setting up to use DH+, to a PLC5, but having trouble where the tag set ups. I can see the processor in the comm set up. But having problem...
1,807
