RS232 or RS485?
The easiest way to send ASCII data from AB to serial devices over distance.
You only have to load the ASCII string(s) into a single string tag in the PLC.
The RTA 435 will handle the serial part.
Flawlessly Robust.
http://www.rtaautomation.com/product/435nbx-2/
We used dozens for ASCII inputs from scanners, and ASCII outputs to printers and dot marking equipment
Seconded. This is a fantastic device.
I'll add my .02 cents as well.
I use Lantronix Xpress DR devices for this type of application. I'm sure they're similar to the RTA Automation device. They'll accept TCP or UDP, can be configured to a specific IP address or will respond to the broadcast address, and will do 232/422/485. I find programming a PLC to manipulate ASCII to be rather clunky. I'd use one of these serial to Ethernet devices and the HMI to handle my ASCII comms.
Oh yeah, I forgot RS-232 is dead
Now that I am at a new company, we use USB bar code scanners.
Thank you RTA for having my back.
I pointed a peer engineer at this to scan in lot and serial number data. Before she started, she was apprehensive on the PLC programming required.
In two minutes from un-packaging this:
http://www.rtaautomation.com/product/435usb-compact/
And clicking it onto the DIN rail, the scans appeared in the string tag in the PLC before her eyes could blink. She "Whoo-hoooed" loudly, and gave me a complimentary fist-bump.
i have an device which can support serial (RS485,RS232),CAN protocol . i want to connect it to an existing MIB 1553B bus ,what device will I need...
99
Hello: I have to connect a RS232 Modbus RTU slave that only has Tx, Rx and GND signals to a Modbus RTU master. However, all RS232 to RS485...
237
HI All, does anyone know if you have to change a cp 341 rs232 and use a cp341 rs485, what changes have to be made to get it to...
1,346
Hi guys Just wondering if anyone has succesfully read barcode data from these barcode scanners to a plc via rs232 or rs485? If so do you guys have...
1,464
I have been using 1761 NET-ENI on my old SLC systems (1747-L532E) Does anyone recommend anything different, Besides changing the processors to...
3,218
