Swapping Siemens CP 341 rs232 to CP 341 rs485
maico
Jun 2012
Belfast
27
HI All,
does anyone know if you have to change a cp 341 rs232 and use a cp341 rs485, what changes have to be made to get it to communicate, the master is set up as rs 485 and all the parameters are set and dongle is installed, I think the cabeling is OK using pin 8 for gnd and pin 11 D+ and pin 4 for D- on the cp341,
Do you have to change the blocks in the program to make this change and if so which ones?
Thx
Hey guys, the scenario is: I have already completed the drawing package for my system utilizing an A-B 440R-N23126 (Minotaur) safety relay. SoS...
141
I just finished a project that was using a CompactLogix(5069-L310ER2)and the project now requires a GuardLogix(5069-L310ERS2). I will be...
624
I had a processor go out on a PLC rack. I am trying to use a different processor because that is what the customer had available. Original was...
1,234
I need to swap out a compact logix 1769-OB16 does the firmware and the series have to match with the new one. Can I upgrade or downgrade the...
1,087
Hi, Looking at installing a L8x redundancy system and have perused the manual. Yep version 1 (beta..) on L8x, probably not the best idea, as well...
1,417
