RS485 and power conductors in 1 cable
quietman187
Aug 2016
Daphne, AL
25
Hi all,
I'm trying to get a bom together for an R&D project.
I have modbus devices that require 355mA for power plus communications. Does anyone know of an online vendor that can supply cable with the RS485 twisted shield AND power (DC) conductors in one cable?
This is for a mobile installation, meaning there is no wire tray and the cables will be rolled out when the job begins then rolled back up when complete, similar to a band touring the country. I'm looking for durability, kind of like an extension cord, people will be stepping on them, this will be in a high traffic construction zone.
Has to be able to be purchased with a credit card, corporate takes 5-8 weeks to add approved vendors.
I would use paired tray cable. 2 pair 16 or 18 should do what you need. Use one pair for power and the other for 485. Real cheap and easily found pretty much anywhere.
+1 Diat150
Polyvinylchloride (PVC)/Polyamide (Nylon) is what you are looking for the jacket material. An alternative would be XLPE (Cross-linked Polyethylene)
Regards,
If any one can share a sample program for communicate micrologix plc with powerflex drive for start/stop and frequency write.. It will be greatful...
2,152
Hi Guys, I hope some of you more knowledgeable people can help me? I'm currently configuring an AB ML1400 to talk to a IME Power Meter over...
4,411
I'm trying to control a device via MODBUS RTU and the ModbusRtuMasterV2_PcCOM in Twincat 3. I've configured a device with the right com port and...
222
Hi, Seeking consultation on an implementation matter, and have a question about Modicon Compact 984 communication through RS485: Three Modicon...
228
i have an device which can support serial (RS485,RS232),CAN protocol . i want to connect it to an existing MIB 1553B bus ,what device will I need...
99
