RS485 Testing
BrendanDixon
Oct 2012
Durban
19
Hi All,
We have been having problems with the communication on a sign board it uses RS485 comunications to communicate between the computer and the sign board. The cable of about 30m tests fine with a multimeter but when I try and communicate nothing will happen. I am trying to make a tester using 2 rs232 to RS485 converters and a program called access port with a RS232 loopback plug on the one converter. but I cannot seem to be able to get this to work as I send text but do not get it back. I am not using the suspected faulty cable.
I have a feeling that is is something to do with the loopback plug as I have pins 2 and 3 bridged and pins 7 and 8 bridged.
1) If you are using two 232/485 converters, then the native communications must be RS-232 on both the PC and sign.
If you put the PC closer to the sign and connect it directly via RS-232, does it work?
Which 232 terminals or pins are needed for this to happen? Just Tx, Rx and signal ground?
2) A loopback plug is a test fixture to prove that what goes out from one end can come back again and be read by the send, given the right test setup. A loopback plug is a substitute for a device on the end. A loopback plug is not used in a working mode, it is only used in a text mode.
A hardwired Loopback test applies to RS-232 only. A 2 wire RS-485 link will not respond to a hardwired loopback test because the tester shorts the (+) and (-) pins together and makes 485 dysfunctional.
3) Unless you tell us what pins 2 and 3 and 7 and 8 are for both ends, it's a mystery. I'm not looking over your shoulder.
4) It's the cable capacitance that limits RS-232 to a 50 ft (15m) limit, but I've lucked out and done 100+ feet (30m).
http://electronicdesign.com/what-s-...e-between-rs-232-and-rs-485-serial-interfaces
It might pay to try directly wiring 30m via RS-232 and see if it works. It will be more subject to electrical noise.
USed some CAT5e for good distances for the 232 stuff also. Easy to find in a pinch too.
I'm trying to test my CP341 RS485 connection. What Am I doing: I send data every second as a test, the TXD led blinks. I've connected a 15...
4,165
I'm trying to control a device via MODBUS RTU and the ModbusRtuMasterV2_PcCOM in Twincat 3. I've configured a device with the right com port and...
286
Hi, Seeking consultation on an implementation matter, and have a question about Modicon Compact 984 communication through RS485: Three Modicon...
298
i have an device which can support serial (RS485,RS232),CAN protocol . i want to connect it to an existing MIB 1553B bus ,what device will I need...
109
Hi all, I am trying to do Modbus communications via the CB1241 RS485 Communication Board on a Siemens S71200 PLC. I am using a 1215C CPU. After...
286
