Rs5000 Import Export. SLC library
WineryPLC
May 2012
earth
I not super new to RS5000 but haven't made a program where I need to do this yet, until now. I am trying to make similar files (same rungs) but with different tags.
In rs500 I would copy to SLC library and Paste but just change the address then update the documentation. 5000 doesn't have this, but I can Export the file and import but cant seem to figure out the tag part. I'm using v19 right now, but will most likely convert the file to v20 by the end of the day.
I don't know if you could accomplish your task the way you have originally envisioned it.
SLCs and Logix CPUs are totally different creatures hence the approaches to this type of editing will not be similar.
"Save As" the original RSL5K application with a different name, "Export Tags and Logic Comments..." to a .csv file; very carefully edit the .csv file as needed; "Import Tags and Logic Comments..." the edited .csv document back into the RSL5K application; "Save".
If changing the CPU firmware revision "Change Controller" within the "Saved As" RSL5K application prior to the Export/Edit/Import.
In RSlogix 5K, If you copy your tags the new tags are going to have a "1" at the end, then copy your rungs and replace original tags with the ones with the "1" at the end, tha's all.
It sounds like you are wanting the same piece of code to run with different "parameters".
Have you thought about using an Add-On Instruction ?
I had a customer email me a .L5X file and said I had to import it into my program. So I created a program just to import that file and see what it...
9,704
I am very 'green' with Wonderware... What it the easiest way to import tags from RS5000 to Wonderware V9. I exported both tag lists to CSV files...
5,219
I have recently made a career change after 25 years of being an electrician. I am officially a junior automation controls programmer. I recently...
368
Hi Guys, Hoping that someone could please confirm if the 1756-IF16/B is/isn't compatible with the 1756-L1 5550 processor(13.24). I'm sure I...
105
Hello, I need help making a logic modification to a RS Logix 5000 program. I can email the program and give plenty of insight to it plus I have...
2,208
