Import Rs5000 tags to Wonderware?
sjameson
Feb 2007
Michigan
I am very 'green' with Wonderware...
What it the easiest way to import tags from RS5000 to Wonderware V9. I exported both tag lists to CSV files but they are not compatible with each other in there respected format. There has got to be any easier way than manually copying the tags from the RS5000 list to the Wonderware list???
Thank for any help!
Sean
You're right - they're not mutually compatible.
I have a spreadsheet that I use to build my tags for both RS5k and WW. I put the info in one time, let excel build the tag definitions, then copy/paste the appropriate excel regions to a text file for import.
It took a little time to setup the first time, but now it's done and I use it every time. Even when I have to create (more than just 1 or 2) new tags...
Hi, I not super new to RS5000 but haven't made a program where I need to do this yet, until now. I am trying to make similar files (same rungs)...
1,859
I had a customer email me a .L5X file and said I had to import it into my program. So I created a program just to import that file and see what it...
9,707
I'm trying to import a .prj file and I keep getting the error message: Project import error. i Any ideas how to get around this? Thanks.
78
Good day colleagues, I have a problem with a plc slc 5 since I export the tags to my factory program to load them into a panel view 1000 plus 6...
118
hey good afternoon ! I have a simple question, I need to import an Add on instruction to a controller that is in operation and cannot stop. Is it...
298
