AdrianCap
Good day colleagues, I have a problem with a plc slc 5 since I export the tags to my factory program to load them into a panel view 1000 plus 6 and it does not read them, I generate the shortcut and they either appear giving it a refresh or adding them manually, someone will let me use them Do you know if a separate procedure has to be done? It is a plc slc 5 it has a panelMate panel but it no longer works and I will change it for a panelview 1000
