Wonderware Window Import Tags "?d:" Prefix
AMarks95
Jul 2018
South Dakota
224
Odd behavior from Wonderware when I imported a couple windows.
All the tags used on the windows already existed, but all of the tags came in with a "?d:" prefix. Why is this prefix added? How can I import without the prefix?
There is a checkbox when importing windows. Says something along the lines of "keep tag names instead of place holders". Basically, keeps the literal tags used, instead of replacing with place holders.
Yes... when importing window you will see check box with something similar to "Retain existing tagnames" at bottom of import window, other wise it will use "placeholders" ahead of tagname as you have seen.
On the ones you have now... Select all the tags in the window and then do a Cntrl-E to edit all the tags, then you can just select "Convert" and it will remove the "?d:". Don't forget to also edit the window scripts.
oh yea... the d means discreet, i means integer and m means message for type of tag
Hi guys. I am using Intouch Wonderware. Does anyone know how to enlarge the AlarmViewerCtrl properties window? In my case it is cut off as in the...
1,496
1st off I'm very new to WonderWare, the program am i needing to modify is version 10.1 The issue that i am having is that while the program...
664
hello... I can work in wonderware intouch window maker easily. But when i switch to Runtime(windowviewer) page, it doesnot open... or may error...
4,408
Good Day guys, I have a problem on showing multiple pop up window. The scenario is this; I have 10 motors and each of them will pop...
4,516
I want to make a button that opens a popup window when pushed, and closes that same window when pushed again. I can't seem to figure out how to...
2,810
