Logix 5000 Tag Import : Local Tags
AMarks95
Jul 2018
South Dakota
224
I know tags can be im/exported from/to an L5K. Wondering if IO tags (Local:1:I) can be overwritten in the same way.
For example, if I have an L5K file generated that contains the descriptions of the local IO, can I import that file to basically auto-fill the descriptions of the IO?
I've noticed the local IO tags are not included in an L5K export, so this may not be possible. Just trying to get rid of the manual typing of IO descriptions. Any advice is much appreciated.
Thanks,
Yes you can include descriptions for Local tags. The local tags don't need to be included in the L5K as they would just needlessly increase the size of the file since they are automatically generated as part of the import.
Go into the .ACD and create a description for a local tag. Then when you do the export you can open the L5K to view the format for that local tag description. Then you can add more as needed directly into the L5K.
OG
Is there any way to use a tag value in the Instance Name field? I would like to have an array of strings with my module names that I can loop...
959
I know the syntax for local tags on various processors varies, but I'm not familiar enough with all of the different PLCs to know which ones will...
2,054
I want to ask about this tag that is in RSLogix 5000: datatype: AB:PowerFlex525V_EENET_Drive:I:0 and I want to create a new tag(instance of...
2,354
Has anyone experienced the following issue on RSLogix5000 (currently on V16) I have a PLC program that has been running on a site for a number...
1,607
I'm trying to be smart about naming my tags so things automatically group together alphabetically, but for some reason it doesn't work like I...
3,642
