Here is the full quote:
FeedForward does not preload the integrator.
With all due deference to Ron - he has posted many long dissertations on the subject of PID control - I would argue that in this particular case, FeedForward may be all you need.
Given:
So, why use the PIDE block at all?
Well, maybe the air flow is approximately constant, maybe the heater response isn't quite as fast as you think, maybe you use a linear transfer function but it's really just close to linear. The errors introduced by these factors can be 'trimmed' out with the PID functions of the block (PV = outlet temp.). The bulk of the CV is the FF and the PID contribution is minor, i.e., coarse and fine controls.
So, I suggest using only FF to begin, then add PID if required.
If transport time is not negligible, then a lead/lag block may be required to condition the FF.
tip: make the cycle time on the SRTP block as short as you can
(emphasis mine)Feed forward value. The value of feed forward is summed with CV after the zero-crossing deadband limiting has been applied to CV. Therefore changes in FF are always reflected in the final output value of CV. If FF < –100 or > 100, the instruction sets the appropriate bit in Status and limits the value used for FF.
Valid = -100.0 to 100.0
Default = 0.0
Given:
- air flow is constant - you say it is compressed air, presumably fed from a regulator.
- transport time (inlet to outlet) is negligible
- heater has fast response
