RS5000 short cut keys
Terry B
Sep 2011
Willisburg Ky
In RS500 you have short cut keys.You press--CTRL+E to access them.
example....
X=XIO
F=XIC
T=TIMER
C=COUNTER
Does RS5000 have them too? If so how do you bring the menu up?
Thanks Terry
Tools->Options->Ladder Editor->Enable Quick Key
Personally I just use the INS (Insert) key on the keyboard and start typing the instruction, look-ahead does most of the work for me, and I don't have to remember another set of short-cuts for the instructions I already know....
And there's no "menu" either, your short-cuts can (if enabled) sit across the top of the ladder window, making that valuable space a bit smaller....
addendum... for the commonly used instructions, you can always use the "Language Element" toolbar, which you can (but I rarely do) scroll through the different instruction categories, to choose the instruction you want.
From the toolbar, you can click, placing the instruction depending on whether you are in "append APP" or "insert INS" mode (bottom right of the screen, right-click it to change it, or Ctrl-I to toggle it), or drag the instruction onto the rung.
Don't forget you can customise the contents of the "Favourites" tab of the Language Element toolbar, adding instructions you will use regularly. There is even another toolbar that is not visible by default, "Ladder Common Logic", that is also configurable.
Just use the INS key, it's easier..... suggest you try it out, I'm sure you'll find it easy to use.
I have recently made a career change after 25 years of being an electrician. I am officially a junior automation controls programmer. I recently...
377
Hi Guys, Hoping that someone could please confirm if the 1756-IF16/B is/isn't compatible with the 1756-L1 5550 processor(13.24). I'm sure I...
109
Hello, I need help making a logic modification to a RS Logix 5000 program. I can email the program and give plenty of insight to it plus I have...
2,217
Hey folks I was wondering how one puts shortcuts on the logic display for instructions. A few weeks back another programmer added them for me...
981
Hello, I'm struggling with getting an email to send using an eweb module on a controllogix system. Any chance I could get someone here to help?
1,869
