RSL5000 ATI instruction?
ceilingwalker
Mar 2010
Phoenix, AZ
1,586
Hello. I went through my instruction lists for the RSL5000 and cannot find an Always True Input, like I have in RSL500. Was it done away with or am I just not seeing it in the options? I am trying to override an output that is written to from an HMI pushbutton, without affecting the other I/O in that circuit. It just seemed the quickest most effective way to do it. Thank you,
No such thing as a ATI instruction in Logix 5000. Just use a non-conditional branch. Or create your own ATI.
Depending on your settings, a "naked" branch will generate a warning upon verification. To get around this, place an NOP instruction in the branch.
I prefer to not use naked branches because they are a challenge to find in the logic. NOP can be found via search. Created ATI tags can be found via a search or cross reference. (y)
I am using version V17.01.00 (CPR 9 SR 1) I have a fairly large machine with multiple PIO nodes on an ethernet network. I am getting a flashing...
1,390
Hello, My coworker and I are commissioning a new panel. We have a 1732-AENTR series C remote IO thats Rev 6.1. The project file from a previous...
1,618
Hello all. Yes, I remember well that RSL5k v.20 was plagued with issues however, it used to run on my laptop. After many years of hibernation I...
1,564
Is there are way to set up RSLogix 5000 to start up with a category in the Controller Organizer 'minimized'? For instance, make the Add-On...
1,740
Hello, I recently converted a control system from PLC-5 to ControLogix and have a question please. My discrete IO converted kind of weird and I...
1,551
