RSLinx backup / restore program
James Mcquade
Oct 2007
Nashville, Tennessee area
3,683
Does anyone know when RSLinx had the backup / restore program added? i have several systems that run rslinx 2.xx which does not have the backup program. is there an alternate way to run the backup program from this older version?
one of next years projects is to plan on updating the software on the pc's but i wanted to get the backup program before something happened.
thanks,
james
i click start > programs > rockwell software > rslinx > and i get the following icons
rslinx
rslinx online reference
rslinx release notes
rslinx service control panel
shortcuts
uninstall rslinx 2.0
the shortcuts does not have the backup icon in the folder.
regards,
james
I'm running into a problem when trying to use the RSLinx Backup Restore Utility where it throws an error when it tries to restore a backup. The...
576
Is there an easy way to export and re-import a network topology for RSLinx Enterprise? I know there is one for RSLinx Classic (Backup and...
10,440
Currently i have my EB_ETH-1 driver setup with an ip for a gateway logix rack The gateway rack have multiple ENBT cads and so my linx config...
3,642
Hi, I am working on a project, where I face a issue with respected to Network Dropout. The PLC is connected to a 16 port unmanaged switch, where...
196
Does Rockwell still offer reset codes for old school Master Disk floppy's? In a bind and need to reset the activation disk soon and to be pointed...
231
