[email protected]
I'm running into a problem when trying to use the RSLinx Backup Restore Utility where it throws an error when it tries to restore a backup.
The message it gives is: "An error occurred while attempting to restore previously saved settings. A subsequent attempt to restore last known good settings resulted in a Registry I/O error. The restore failed due to error 5: Access is denied".
I'm running Windows 10, version 22H2. The version of RSLinx (Classic) is 4.30.00.
What I've tried so far:
- Run the tool as administrator.
- Stop RSLinx and Harmony services.
- Reboot the PC and do both of the above.
- Windows Compatibility troubleshooter -tried every setting I could think of.
The result is always the same.
It does not matter what backup I select - even if I create a new backup and immediately try to load it without ever closing the tool.
One thing that I'm not clear on is whether the error is associated with the registry access, the backup file itself, or the current settings in RSLinx? It sounds like a registry access problem, but I am able to edit and change the RSLinx drivers from RSLinx, so registry access 'seems' to be okay.
I do have a ticket submitted with Rockwell, but have not heard back yet. Thought maybe someone else might have run into this and had a solution handy?
Many thanks for anyone's eyes on this!
