RSLinx bump up to 2.5 CPR 7
russrmartin
Aug 2002
Eastman, Wisconsin
744
Hey guys, has anyone else had problems bumping Linx to version 2.50? I downloaded the file from AB and all I get are HKey errors when I try to run it. Has this worked real smoothly for everyone else, or is it a pain in the butt for all yall too.
Russ
Thanks guys
Thanks for the responses. One of my installs was a comp. problem, as it installed fine on a different laptop. The troubled one is running 2000, the XP one installed fine. I am experiencing some of the problems listed in the hotfix though. We will try running that. Thanks again.
Russ
I don't have a whole lot of experience with RSLinx Enterprise or I guess it's also called FactoryTalk Linx. We have a Rockwell FTView SE based...
54
I have 2 PLCs. One is networked to our plant, and the other is networked to the first PLC via a 1756-EN2T. I could easily get the second PLC...
81
Hi, I am working on a project, where I face a issue with respected to Network Dropout. The PLC is connected to a 16 port unmanaged switch, where...
230
Does Rockwell still offer reset codes for old school Master Disk floppy's? In a bind and need to reset the activation disk soon and to be pointed...
277
Anyone have issues with RSLinx being very slow to open. It sometimes will say "Checking Activation" at the bottom for what seems like an...
196
