RSLinx CIP API (Ethernet/IP)
noznoz
Aug 2006
San Jose
I am trying to develop the C++ application with RSLinx CIP API.
This application will send the CIP message to CompactLogix via EtherNet/IP with DTL_CIP_MESSAGE_SEND_W function in API.
But I have a trouble to connect via EtherNet/IP. I don't understand how to set baPath in DTL_AB_CIP_PATH structure.
Sample program by Rockwell shows only the example using ControlNet not EtherNet/IP.
Would appreciate if someone provide me the sample program to connect via EtherNet/IP or how to set the baPath when using EtherNet/IP.
Thank you
take a look at:
A4195 - RSLinx C SDK: Routing thru the ControlLogix Gateway
in the RA knowledgebase.
this *might* have the info you are looking for
Any update on this? We're using EtherNet/IP going from the processor to RSLinx SDK, and are running into some trouble due to the use of CIP messaging, and that being compeltely separate from the standard SDK functionality.
Anyone have experience with the SDK, CIP messaging, or interacting with RSLinx and EtherNet/IP sans OPC?
I've built a vmhost (ESXI 7) to host the control's engineers W7 machines used to connect to the PLCs. I'm using a Stratix 5700 to NAT the PLCs...
2,412
I use RSEmulate V20 and RSLinx Classic Gateway to interact with a simulator and an HMI. Sometimes, a system will become less stable and...
1,351
We presently have a Wonderware application using RS LINX PRO /opc dde communicating via a 1761 NET ENI module to a compact logix L30 processor. We...
4,203
I don't have a whole lot of experience with RSLinx Enterprise or I guess it's also called FactoryTalk Linx. We have a Rockwell FTView SE based...
61
I have 2 PLCs. One is networked to our plant, and the other is networked to the first PLC via a 1756-EN2T. I could easily get the second PLC...
86
